![]() | Home > Puma (Tdci) > Alarm reset after new master battery 2008 puma 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Press lock or un-lock around 5 times quickly with all doors shut.
Watch the dash, the alarm LED will flash fast then go back to normal speed. After this it should be back to normal. |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Just Been out n tried that Steve
![]() Made no difference though ![]() |
Try more than 5 times, I can't recall the exact number of presses. It doesn't matter.
If that still doesn't work does it have a battery backed up alarm sounder on yours or not? Either way, disconnect the battery for 5 minutes then reconnect it and try the procedure I mentioned. How old was your battery? If not that old are you sure there isn't battery drain through something wrong. Possibly central locking related but a stab in the dark. |
