Home > Puma (Tdci) > Alarm reset after new master battery 2008 puma 90
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, sorry if this has been covered before , but I couldn't see it Very Happy
Replaced the main vehicle battery this afternoon, it wasn't flat but wouldn't hold charge for more than a few days,
So probally only disconnected 10-15 mins max,
All started up fine,
But can't seem to get the alarm fob to lock / unlock any more ?
I have locked the vehicle with the key and they all locked fine,
Any tips please ?
Thanks in advance
Post #527857 29th Apr 2016 6:07pm
Press lock or un-lock around 5 times quickly with all doors shut.
Watch the dash, the alarm LED will flash fast then go back to normal speed.
After this it should be back to normal.
Post #527869 29th Apr 2016 6:36pm
Daisy90
Just Been out n tried that Steve Thumbs Up
Made no difference though Neutral
Post #527922 29th Apr 2016 9:45pm
Try more than 5 times, I can't recall the exact number of presses. It doesn't matter.
If that still doesn't work does it have a battery backed up alarm sounder on yours or not?
Either way, disconnect the battery for 5 minutes then reconnect it and try the procedure I mentioned.
How old was your battery? If not that old are you sure there isn't battery drain through something wrong.
Possibly central locking related but a stab in the dark.
Post #527923 29th Apr 2016 9:52pm
