Home > Technical > Headliner fir tree removal help
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I'm trying to remove the roof lining inside my 90 which I need to refit once covered in alcantare but I cant seem to remove the fir tree clips?
I purchased PANEL TRIM CLIP REMOVAL PLIERS & UPHOLSTERY REMOVER PRY BAR TOOL below:
http://www.ebay.co.uk/itm/CAR-DOOR-CARD-PA...1731600808
which I thought would be the correct tools for the job? All I seem to be able to do with them is break the heads off the clips just after I've dug holes in the headlining..... Banging Head
Any advice on how to remove the aforementioned Censored clips would be gratefully appreciated Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #527382 27th Apr 2016 7:52pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Brake / cut them off then remove headliner once out punch them through and use new ones
Post #527383 27th Apr 2016 7:53pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Do as Dave says, then if you want black ones, Halfords sell packs of 8, exactly the same as LR for less than £3. I ordered 5 from LR which cost nearly £2 each, they were on back order, never got them, so got my money back.
Good luck
Andy
Post #527390 27th Apr 2016 8:18pm
Butchers Boy
^^^^ Thumbs Up ^^^^ Thanks guys...!!
Certainly no problem in braking the heads off them I got that bit down to a tea Rolling with laughter
Any idea what thickness they are? I might need longer one's I want to line the roof with 10mm Sound & Heat Insulation paneling before I refit the roof lining 2010 Defender 90 HT
Post #527401 27th Apr 2016 8:55pm
dave18
Just take the remnants of one with you. Shouldn't need longer ones as the bracing they go onto is nearly an 25mm thick
Post #527462 27th Apr 2016 11:55pm
familymad
Search for headliner clips on eBay and 10 for £3.99 delivered Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #527537 28th Apr 2016 2:14pm
gilarion
I use a claw hammer and a thick piece of card, wiggle claw of the hammer under the head of fir tree, place thick cardboard under hammer head so as not to damage headlining and just lever them out, simples! For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #527540 28th Apr 2016 2:31pm
CarMan
No expense spared, I bought one of these and share it with a mate: http://www.ebay.co.uk/itm/Silverline-Car-D...Sw2XFUY58a Wink Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #527585 28th Apr 2016 5:56pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
^^^^^ me too perfect for the job Thumbs Up Cogito ergo sum
Post #527592 28th Apr 2016 6:23pm
