![]() | Home > Technical > Headliner fir tree removal help |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
I'm trying to remove the roof lining inside my 90 which I need to refit once covered in alcantare but I cant seem to remove the fir tree clips?
I purchased PANEL TRIM CLIP REMOVAL PLIERS & UPHOLSTERY REMOVER PRY BAR TOOL below: http://www.ebay.co.uk/itm/CAR-DOOR-CARD-PA...1731600808 which I thought would be the correct tools for the job? All I seem to be able to do with them is break the heads off the clips just after I've dug holes in the headlining..... ![]() Any advice on how to remove the aforementioned ![]() ![]() The longer I live..... The better I was! |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Brake / cut them off then remove headliner once out punch them through and use new ones
![]() Certainly no problem in braking the heads off them I got that bit down to a tea ![]() Any idea what thickness they are? I might need longer one's I want to line the roof with 10mm Sound & Heat Insulation paneling before I refit the roof lining 2010 Defender 90 HT The longer I live..... The better I was! |
Just take the remnants of one with you. Shouldn't need longer ones as the bracing they go onto is nearly an 25mm thick
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
Search for headliner clips on eBay and 10 for £3.99 delivered
![]() 1995 110 300TDI 1995 90 300TDI |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
I use a claw hammer and a thick piece of card, wiggle claw of the hammer under the head of fir tree, place thick cardboard under hammer head so as not to damage headlining and just lever them out, simples! For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1902 ![]() ![]() |
No expense spared, I bought one of these and share it with a mate: http://www.ebay.co.uk/itm/Silverline-Car-D...Sw2XFUY58a
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
^^^^^ me too perfect for the job
