Home > Maintenance & Modifications > Bent Rear Axel?
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Bent Rear Axel?
Posting for a mate.
His rear tyres have worn bald on the inside of his 2008 110 Puma.
He changed the trailing arm bushes which has some play but it hasn't cured the problem.
Here's facebook post to a Landy Group
"Before I rush out and buy a new rear axle.. Is there any other possible explanation for this other than bent rear axle??? (It just seems so perfectly wrong!)
Next question.. Will a 2009 2.4Puma 90 rear axle fit straight onto my 2008 2.4Puma 110??
Many thanks.
Post #527346 27th Apr 2016 5:56pm
90 and 110/130 axles are different and not interchangeable (at least, not easily). They have completely different diffs for a start.
Post #527372 27th Apr 2016 7:36pm
danridge
Thanks Will pass that on
Post #527410 27th Apr 2016 9:31pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
The 90 axle will fit no problem , but you'll need a shorter prop shaft as the 110 has a short nose diff
Post #527440 27th Apr 2016 10:30pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
I thought the rear rover pattern axle wasn't weight rated for a 110 hence the p38a being used? Rhubarb and custard let fly with their secret weapon.
Post #527469 28th Apr 2016 5:24am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
If each side was toeing 10 degrees out each side, it would be massively noticeable, even visually!
Post #527477 28th Apr 2016 7:19am
jst
axle will physcially fit but the 110 has a P38 diff (same ratio as 90) 3.54 and the 90 has a std LR diff.
so as above prop will need shortening to fit the 90 axle into a 110
you cant swap the diffs over as the bolt pattern is different.
i dont recall LR ever fitted std rover diffs to the back of a 110, they were salisbury then went to P38 pattern.
must be good reason for the added expense! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #527617 28th Apr 2016 8:12pm
