![]() | Home > Maintenance & Modifications > Bent Rear Axel? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
90 and 110/130 axles are different and not interchangeable (at least, not easily). They have completely different diffs for a start.
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 ![]() ![]() ![]() |
Thanks Will pass that on
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 ![]() ![]() |
The 90 axle will fit no problem , but you'll need a shorter prop shaft as the 110 has a short nose diff
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
I thought the rear rover pattern axle wasn't weight rated for a 110 hence the p38a being used? Rhubarb and custard let fly with their secret weapon.
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
If each side was toeing 10 degrees out each side, it would be massively noticeable, even visually!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8359 ![]() ![]() ![]() |
axle will physcially fit but the 110 has a P38 diff (same ratio as 90) 3.54 and the 90 has a std LR diff.
so as above prop will need shortening to fit the 90 axle into a 110 you cant swap the diffs over as the bolt pattern is different. i dont recall LR ever fitted std rover diffs to the back of a 110, they were salisbury then went to P38 pattern. must be good reason for the added expense! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
