Home > Technical > TD5 Headlights
luckygoldstar
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
TD5 Headlights
Just had a headlight failure ..sidelights turn on but the headlights do not...main beam works on flash only...first time it happened took the column apart checked switch as all wisdom suggested that...but was in good nick...the relay was heard to buzz/chatter...??? anyhow on reconstructing the column lights started working ....and being lazy I forgot about it till they failed in the lanes....at night...and its pitch black round here...have been advised to change pink relay...so its a know fault ? any help appreciated. K
Post #524741 17th Apr 2016 3:00pm
Almost certainly the headlight switch
Post #524755 17th Apr 2016 3:48pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Had a similar problem with my 300Tdi (I'm pretty sure the switch in question is the same with a different connector). It turned out to be the contacts in the Stalk switch that controls the main beam and flash. One of the contacts had become loose and floated just enough to break contact.
Worth having a look there. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #524757 17th Apr 2016 3:52pm
luckygoldstar
I took out the switch unit ...and it looks brand new..had a good look at the contacts ?
Post #524777 17th Apr 2016 5:00pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
switch is the No1 cause if you are running the full amps through it.
check by bypassing it and shorting the contacts
.....after checking which are which with a meter
CC
Post #524824 17th Apr 2016 7:59pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
I had the same issue on one of my trucks. It turned out to be the connectors on the loom plug just before the stalk. The multi plug was white and sat just below the main column and could easily be found by tracing the feed back a few inches from the stalk once the column shroud is removed.
The cause was still the same- too much current flowing through and the pin for the main power feed had corroded and failed under load.
Takes two minutes to bypass though with suitable cable Thumbs Up 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone )
2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone)
Post #524857 17th Apr 2016 9:38pm
luckygoldstar
will have a look...am 260 miles from home now...and I forgot to pack the socket for the steering wheel!
Post #524880 17th Apr 2016 10:54pm
