Riccarton
Drain it out immediately, fill with the correct stuff, bleed, then drain again and re-fill.
It won't cause a sudden failure but may have damaged the seals (pump & box) so keep an eye out for any leaks starting.
Good luck
14th Apr 2016 9:00am |
