![]() | Home > Puma (Tdci) > Advice for broken gearbox |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/DEFENDER-2-2-GEA...Sw2ENW7TFk
Where abouts in France are you? Keith |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
Thanks for the link, but it has only done 30,000 miles, so I was hoping to get just the fork changed rather than buying a new gearbox.
No worries, just thought I would show the link as I am on the ferry to St Malo & down to la Rochelle area on Saturday with the trailer and probably enough space....
Keith |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
I am very sure that there is a workshop manual for that gearbox. So I would first read about the correct procedure to dismantle the gearbox. I would be surprised if it needed cutting - and if it was seized and needed cutting I don't think that there would only be a problem with a fork.
If it were mine I would get an exchange box from UK or a good secondhand. The exchange box should be from someone (I use Ashcroft) who regularly repairs such gearboxes and has the correct spares (particularly shims etc) to put it together correctly. If you want to see how much your garage knows ask them exactly what oil they intend to put back into the gearbox once repaired. Compare that to the correct spec in the vehicle handbook? Hope this helps Nick 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Search for "GTF MT-82 garageforum.org" on google. If it was me, I wouldn't let the indy botch the gearbox... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
http://forums.lr4x4.com/index.php?showtopic=55983&page=4
defender M12 work Manuel |
Ickle - very generous of you, thank you! I am a long way from La Rochelle, but it is much closer than the UK for sure. I still want to try and get this fairly new box fixed though rather than replaced.
Thanks to the others for links to parts and manuals etc. I already have the manuals and so does the garage (and were trying to dismantle as per the manual - which mentions the heating). However, the heating up would not free it, so I was hoping someone that has stripped one of these boxes before may be able to offer some tips of how to finish the job? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
A bit drastic I know I would take a few days leave and take the box to Ashcroft personally , do it right fix it once
