Home > Puma (Tdci) > Advice for broken gearbox
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Some weeks ago I posted in another thread that my Puma was stuck in first gear. This has now moved onto a different problem, so starting a new thread.
Local independent garage managed to free the gear, but it jammed again after a few metres. They took the box out and think it is a broken fork. They have heated it up to get more access to the internals and repair, but are unable to extract. picture below shows what it looks like so far - unable to proceed any further after trying pullers and heat. They think the next step is to cut into it, which seems a bit extreme.
Is anyone able to offer any advice on how to best proceed please?
From the other post, Ashcroft said they could fix it, but unfortunately shipping from here in France looks to be difficult and expensive. Also seems crazy something like this can't be fixed without having to ship across Europe! Should the garage continue and cut? Or there there some other tips I could pass on? As it is on the bench I could take it to a main dealer, but would they likely to be able to do any better?
Any advice welcome. This has been over 6 weeks now...
Many thanks.
Post #523066 11th Apr 2016 2:34pm
ickle
http://www.ebay.co.uk/itm/DEFENDER-2-2-GEA...Sw2ENW7TFk
Where abouts in France are you?
Keith
Post #523124 11th Apr 2016 5:52pm
Tribord
Thanks for the link, but it has only done 30,000 miles, so I was hoping to get just the fork changed rather than buying a new gearbox.
Post #523144 11th Apr 2016 7:21pm
ickle
No worries, just thought I would show the link as I am on the ferry to St Malo & down to la Rochelle area on Saturday with the trailer and probably enough space....
Keith
Post #523151 11th Apr 2016 7:32pm
dorsetsmith
Post #523171 11th Apr 2016 8:12pm
nickhodgson
I am very sure that there is a workshop manual for that gearbox. So I would first read about the correct procedure to dismantle the gearbox. I would be surprised if it needed cutting - and if it was seized and needed cutting I don't think that there would only be a problem with a fork.
If it were mine I would get an exchange box from UK or a good secondhand. The exchange box should be from someone (I use Ashcroft) who regularly repairs such gearboxes and has the correct spares (particularly shims etc) to put it together correctly.
If you want to see how much your garage knows ask them exactly what oil they intend to put back into the gearbox once repaired. Compare that to the correct spec in the vehicle handbook?
Hope this helps
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #523248 12th Apr 2016 7:40am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Quote:
I am very sure that there is a workshop manual for that gearbox. [...]
Search for "GTF MT-82 garageforum.org" on google. If it was me, I wouldn't let the indy botch the gearbox... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #523252 12th Apr 2016 7:56am
dorsetsmith
Post #523259 12th Apr 2016 8:22am
Tribord
Ickle - very generous of you, thank you! I am a long way from La Rochelle, but it is much closer than the UK for sure. I still want to try and get this fairly new box fixed though rather than replaced.
Thanks to the others for links to parts and manuals etc. I already have the manuals and so does the garage (and were trying to dismantle as per the manual - which mentions the heating). However, the heating up would not free it, so I was hoping someone that has stripped one of these boxes before may be able to offer some tips of how to finish the job?
Post #523276 12th Apr 2016 9:00am
ibexman
A bit drastic I know I would take a few days leave and take the box to Ashcroft personally , do it right fix it once
Post #523289 12th Apr 2016 9:30am
