![]() | Home > Maintenance & Modifications > Grille insert replacement (air con model) recommendations? |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
I guess there must be some UK based suppliers of those, but if not, there always is Entreq in Germany for top quality.
Eric http://www.entreq.de/protection-gear/kuhlergrill.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Have a look here
Brendan |
| Mwd Member Since: 12 Jan 2016 Location: Scottish Highlands Posts: 45
Fitted the naked stainless steel Nakatanenga from 4x4 overlander today and it fits perfectly and looks great. I used stainless torx-headed machine screws with nyloc nuts rather than pop rivets, mainly because I was worried I'd crack the plastic part of the grille if I messed up the rivets. The factory grille I removed looks like plain aluminium with a quick spray of body colour paint from the front - no wonder the paint flaked off so quickly!
| HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131
Have seem some RCX ones on ebay, I need to buy some also.
RCX do a black finish as well as silver - black could look more 'sporting'... 2002MY Defender 90 H/T |
| Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060
Using a non-AC Nakatanenga Heritage grille on an AC equipped Defender worked well for me. The grille extends down covering the lower opening (negating the need for the original grille). I had to fold the (originally flat) aluminium grille to fit.
On request of another D2net member, i looked the part up on Nakaīs website, and couldnīt find it listed anymore (Non AC Heritage grille in silver). 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Have to say that with regard to the intercooler grill they are all like that - see - http://www.defender2.net/forum/topic34820....p;start=15 Click image to enlarge Was yours still under warranty? I took mine off and had it repainted separately by the main dealer - it was covered under warranty and is now perfect. Why waste money on aftermarket parts when it can be fixed correctly fo free? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
Very nice truck !!! Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
WC90 the Nakatanenga code is KGHTLAL-S for non air con in silver heritage style grill.
Also available HERE Brendan |
Brendan, thanks
I can thoroughly recommend this, in combination with the matching headlamp surrounds. All painted aluminium. i liked the clean classic look, and getting rid of the less than imspiring original grille has got to be a bonus. Straightening up the wings is a must, too (covered in a thread elsewhere on here). Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| LordArmstrong66 Member Since: 21 May 2020 Location: London Posts: 1
Could you please tell us how you went about bending the grill to shape and what problems you encountered? I have found the grill but am wondering whether the corners will buckle outwards as they are bent. Cheers. P.S. sorry due to this being a new account I canât PM |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
First thing I did when I got mine, took the grill out by drilling the rivets, electric samder to cut to good metal, 2 coats of etch primer on both sides. 2 coats of satin black. some nice M5 x 12mm button headed hex bolts from Pro Bolt - Looks great
Click image to enlarge Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
