Home > Maintenance & Modifications > Grille insert replacement (air con model) recommendations?
Mwd
The grille insert at the bottom of my 2.2 Puma is looking tatty. I think it's aluminium with a poor factory paint finish which has now flaked and exposed the corroded metal. I'd like to replace the offending part with a stainless steel substitute and was hoping someone could recommend something. I've found one on Zunsport that looks like it would do the job but would be grateful for any advice! Thanks
Post #511049 5th Mar 2016 5:05pm
ericvv
Post #511052 5th Mar 2016 5:10pm
leeds
Have a look here
Brendan
Post #511054 5th Mar 2016 5:19pm
Mwd
Fitted the naked stainless steel Nakatanenga from 4x4 overlander today and it fits perfectly and looks great. I used stainless torx-headed machine screws with nyloc nuts rather than pop rivets, mainly because I was worried I'd crack the plastic part of the grille if I messed up the rivets. The factory grille I removed looks like plain aluminium with a quick spray of body colour paint from the front - no wonder the paint flaked off so quickly!
Post #517757 25th Mar 2016 8:22pm
HossBog
Have seem some RCX ones on ebay, I need to buy some also.
RCX do a black finish as well as silver - black could look more 'sporting'... 2002MY Defender 90 H/T
Post #517847 26th Mar 2016 8:40am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Using a non-AC Nakatanenga Heritage grille on an AC equipped Defender worked well for me. The grille extends down covering the lower opening (negating the need for the original grille). I had to fold the (originally flat) aluminium grille to fit.
On request of another D2net member, i looked the part up on Nakaīs website, and couldnīt find it listed anymore (Non AC Heritage grille in silver).
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #517866 26th Mar 2016 9:38am
grafty99
Cool 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #517873 26th Mar 2016 10:21am
Re: Grille insert replacement (air con model) recommendation
Have to say that with regard to the intercooler grill they are all like that - see - http://www.defender2.net/forum/topic34820....p;start=15
Was yours still under warranty?
I took mine off and had it repainted separately by the main dealer - it was covered under warranty and is now perfect. Why waste money on aftermarket parts when it can be fixed correctly fo free?
Post #517875 26th Mar 2016 10:35am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Very nice truck !!!
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #517883 26th Mar 2016 11:19am
leeds
WC90 the Nakatanenga code is KGHTLAL-S for non air con in silver heritage style grill.
Also available HERE
Brendan
Post #517889 26th Mar 2016 11:33am
Wild Card 90
Brendan, thanks Thumbs Up .
I can thoroughly recommend this, in combination with the matching headlamp surrounds. All painted aluminium. i liked the clean classic look, and getting rid of the less than imspiring original grille has got to be a bonus. Straightening up the wings is a must, too (covered in a thread elsewhere on here).
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #517894 26th Mar 2016 11:51am
LordArmstrong66
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
On request of another D2net member, i looked the part up on Nakaïŋ―s website, and couldnïŋ―t find it listed anymore (Non AC Heritage grille in silver).
Could you please tell us how you went about bending the grill to shape and what problems you encountered? I have found the grill but am wondering whether the corners will buckle outwards as they are bent.
Cheers.
P.S. sorry due to this being a new account I can’t PM
Post #832400 21st May 2020 3:35pm
The Zee
First thing I did when I got mine, took the grill out by drilling the rivets, electric samder to cut to good metal, 2 coats of etch primer on both sides. 2 coats of satin black. some nice M5 x 12mm button headed hex bolts from Pro Bolt - Looks great Thumbs Up
 Zaid-M
www.DefencePhotos.com
Post #832422 21st May 2020 6:12pm
