Home > Puma (Tdci) > turning circle
dudley472
United Kingdom 2009 Defender 90 Puma 2.4 HT Keswick Green
turning circle
I just changed my 09 90 for a 2014, one thing I notice right away the turning circle is terrible compared to my old one, is this a known thing? can I adjust the lockstops ?
Post #509503 1st Mar 2016 10:42am
mk1collector
Yeah, just adjust the stops and all should be normal small oil tanker turning circle instead of big oil tanker Rolling with laughter Ray
My build thread
Post #509505 1st Mar 2016 10:48am
dorsetsmith
Re: turning circle
have look at the link
http://defender90xs.blogspot.co.uk/2013/11...tment.html
Post #509509 1st Mar 2016 11:13am
X4SKP
Post #509514 1st Mar 2016 11:36am
Doubledoom
United Kingdom 2016 Defender 90 Puma 2.2 SW Santorini Black
Should there be any difference between an 09 and 14 in respect of turning circle?
I didnt think they had got any worse but were equally as bad.
Post #509524 1st Mar 2016 12:05pm
discomog
I love Ray's analogy of small oil tanker/big oil tanker. Laughing Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #509525 1st Mar 2016 12:06pm
dudley472
perfect thanks very much,
Post #509539 1st Mar 2016 1:06pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I adjusted my stops yesterday and can confirm the above statement about oil tankers Rolling with laughter
Post #510438 3rd Mar 2016 6:08pm
Thon
I used to be an avid trialer with my first 90 and had the lock stops adjusted so the tyre would touch the radius arm.
Every little helps when you're trying to squeeze between the gates Smile
Post #510449 3rd Mar 2016 6:35pm
RRUK
Question.
When adjusting, do you adjust with the wheels turned inwards or outwards or both? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #510455 3rd Mar 2016 6:43pm
mk1collector
Adjusting the n/s stop check on the rear of the o/s wheel and vice versa. Ray
My build thread
Post #510459 3rd Mar 2016 6:50pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
It depends on what wheels you had on the two vehicles, and whether they are both set up for maximum lock.
Wider offset wheels allows you to dial in more steering lock, and thereby improve the turning circle. Spacers have the same effect. With the wide offset of the ZUīs and 30mm spacers, my 90 turns "on a dime". 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #510471 3rd Mar 2016 7:18pm
