Home > Puma (Tdci) > Clutch and shifting problems
Alexke
Belgium
Hi guys!
Just wanted to have a second opinion ,
for nearly 6 months the car sometimes shifts bad , downshifts are imposible without rev matching.
The stealer couldnt find the problem , but changed the gearbox fluid anyway. it was a bit better.
now last week I was on the moterway and wanted to shift from 5th to 6th , and the clutch pedal sank quickly to the floor. I did managed to shift perfectly to 6th. Being afraid I just hooped the clutch cylinder I waited on an exit to try my clutch again.
This time it had pressure again and i managed to declutch. putting car into gear was more difficult tho.
this week I had it happen 1 time again.
Yesterday I compared it to a TD5 and my clutch was much lighter.
Clutch doesn't slip while on power (dealer always asks if my TD4 is tuned , its not).
I was among the first in Belgium to have the dreaded exploded clutch @ 34.000km , its now running 112.000km.
I booked the car already at an independent shop to replace my master cylinder. The clutch fluid is black but its not leaking.
I hope this is the problem , and not some other fault.
anyone had this one yet? Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #509289 29th Feb 2016 4:33pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Have you had the shims put under the gear selector? I had trouble selecting some gears and this seemed to fix it, I'm sure there is a how to on here somewhere. The dealer did mine under warranty.
Post #509293 29th Feb 2016 4:40pm
Alexke
Belgium
maybe , but that does not explain my clutch pedal pressure Big Cry
I will adres that problem as well to make sure. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #509538 1st Mar 2016 1:05pm
Assuming that the fluid level is correct, I would suspect that the seals in either the master or slave cylinder are failing, so the clutch is not disengaging fully.
Post #509566 1st Mar 2016 2:08pm
mk1collector
I'd say seals too as the fluid is black. Ray
My build thread
Post #509611 1st Mar 2016 5:15pm
Alexke
Belgium
I replaced the master cylinder , the truck does shift a lot better. upshifting is better but still not easy at high rpm (downhill)
upshifts pop into gear easy , before I had to force them in.
feel so bad for my syncro´s now...
thanks guys!
Will do the shims when I have time.
repair costs :141euro parts and labor[/b] Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #510214 3rd Mar 2016 8:46am
