![]() | Home > Puma (Tdci) > Clutch and shifting problems |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Have you had the shims put under the gear selector? I had trouble selecting some gears and this seemed to fix it, I'm sure there is a how to on here somewhere. The dealer did mine under warranty.
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
maybe , but that does not explain my clutch pedal pressure
![]() I will adres that problem as well to make sure. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17873 ![]() ![]() ![]() |
Assuming that the fluid level is correct, I would suspect that the seals in either the master or slave cylinder are failing, so the clutch is not disengaging fully.
I'd say seals too as the fluid is black. Ray
I replaced the master cylinder , the truck does shift a lot better. upshifting is better but still not easy at high rpm (downhill)
upshifts pop into gear easy , before I had to force them in. feel so bad for my syncro´s now... thanks guys! Will do the shims when I have time. repair costs :141euro parts and labor[/b] Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
