Home > Puma (Tdci) > Cold weather package brand new 2016MY
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
Picked up my new defender this month. it arrived without 2 options I ordered, heated seats and windscreen. The dealer refunded the option price, but I asked if these can be installed anyway by ordering the required parts. He told me , no the wiring is not there and would be difficult, then he told me I don't need them anyway because the seats don't heat very well, just a couple of wire strips in the bottom (its not like a range rover he said) and the windshield is mainly for arctic countries. I still want them but is the dealer correct on his points, that they will be difficult to retrofit and not work well anyway
THANKS
SALLDHMR8GA488xxx is a XS model is not supposed to be standard
thanks!!! Big Cry Big Cry
This post has been edited by the site administration team: full VIN edited out
Post #508302 26th Feb 2016 12:06am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
The seats don't heat very well? Is he serious?!!
Heated seats and windscreen. One of the few things on a Defender that work very well. Wouldn't want to be without them.
Post #508308 26th Feb 2016 12:16am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Sounds to me like he's fobbing you off. I would have insisted on the options as that is what you ordered. Seems you haven't got what you paid for and refunding the cost is a cheap way for the dealer to get out of their obligation rather that retro fitting them.
Heated screens and seats work very well and I find them to be essential items during British winters, especially on frosty mornings.
Maybe it's worth sending Ryan a PM. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #508311 26th Feb 2016 12:17am
TJ101
Heated seats and screen, were std fit for UK XS models California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #508312 26th Feb 2016 12:19am
AdrianCR
strange and this is the last one..
2 SPEAKERS FRT/2 SPEAKERS RR7.0X16 ALLOY ROAD WHL-STYLE 1110 INCH/2794MM WHEELBASE315 MHZ DOOR LOCK FREQUENCY3050 KG GVM @ 1250 FR/1850 RRAIR CONDITONING-MANUALALPINE HARD TOP-PLAINALTERNATOR-150 AMPAXLE DIFFERENTIAL - REAR 2 PINAXLE DIFFERENTIAL-FRONT 2 PINBADGE- REAR-DEFENDER-TITANBLUE TOOTH INTERFACE CONNECTBODY COLORED PAINTED ROOFBODYCOLOR WHEELLIP MLDGBRUNEL HEADLAMP MOLDINGSBUMPER UNDERRUN-FRONT-N2CARPET FLOOR COVERING-LEVEL 1CONSOLE-WITH CLOSED BINCORE DEFENDER CONSOLE MATERIALCOSTA RICADAY/NIGHT INSIDE MIRRORDIESEL FUEL CAPABILITYDOOR ENTRY REMOTE CNTR UNITDR HANDLES-INS MOLD IN BLACKDRIVER SEAT - STANDARDDRVR & PASS SEAT MAP POCKETSEBONY HEADLINERELECTRIC REAR WINDOW DEFROSTERENGINE POWER SOURCE - 122/360ENGINE TRACTION CNTRL BRK(DNU)EURO STAGE 4 EMISSIONSFOOT PEDAL DESIGN - STANDARDFRT BMPR-GLOSS BLK/GLOSS BLKGOODYEAR MTRGRILLE-BRUNELHALOGEN HEADLAMPSHIGHLINE ICEHOOD BADGE - DEFENDER BRUNELI/P INSERT - GRAPHITEINSTRUMENT PANEL -BASEINTR GRAB HANDLES - 6JACK-HEAVY DUTYKPH SPEEDOMETERLOCKING WHEEL LUG NUTMANUAL TELESCOPIC RADO ANTENNAMOLDED GEAR SHIFT KNOBMUD FLAPS - FRONTPASSIVE SEAT BELTS-FRONTPERIMETER /VOLUME THEFT SYSTEMPLASTIC HANDBRAKE GRIPPOWER FRONT SIDE WINDOWS PRIVACY GLASS PVC DOOR TRIM PANEL REAR DOOR POCKET STOWAGE REAR STEP ASSEMBLY REAR WINDOW WASHER/WIPER RR DR SPARE WHL CARR RR QTR VEN WDO-FXD SECURITY SIREN-BATTERY BACKUP SERAPHINITE/SCOTIA GREY SEVEN PASS SEAT CONFIGURATION SLIDING REAR SIDE WINDOW SOLIHULL ASSEMBLY (UK) SPANISH OWNER HANDBOOK #2 SPECIAL VALUE PACK E STABILIZER BAR-FRONT REAR STANDARD DUTY SUSPENSION STEP-SIDE RUNNERS STNG WHL-LEATHER WRAPPED T/TOW HTH-D/PLATE/BALL 7P TAILLAMPS-LEVEL 2 TRANSFER BOX - RATIO 1.2 VENTILATED DISC BRAKES WHEEL LOCKSTOP LESS BRAKE LIMITING VALVE LESS BULK HEAD LESS CARGO STOWAGE DEVICE LESS CHEQUER PLATES LESS CONTRAST STITCHING LESS DIM-DIP HEADLAMPS PACKAGE LESS ELECTR SPEED LIMITATION LESS FRONT FLOOR MATS LESS FRONT TOWING PIN LESS HALF DOOR LESS HEATED FRONT WINDSCREEN LESS HOODS LESS LOADSPACE COVER LESS MUDFLAPS-REAR LESS ROOF OPENING PANELS LESS SEAT TEMP CONTROL LESS SPARE TIRE COVER LESS TAILGATE LESS TOOL KITS LESS UNDERBODY PROTECTION LESS VEHICLE DECALS
Post #508316 26th Feb 2016 12:31am
JWL
My retro fitted heated screen is used as much in our glorious moist summers as it is in the colder weather. Nothing worse than a misted up windscreen when it's warm and raining, as soon as you get inside with the kids all breathing and with wet coats the windows mist up allmost immediately, the heated screen comes into its own then Thumbs Up
Post #508319 26th Feb 2016 12:35am
mcl001
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Agree with previous posts
Heated screen and seats are excellent
Have had heated seats in various be buckets and are quicker and hotter than most such as Nissan Navara.(sorry for swearing on forum!)
Personally I would not have accepted a refund of the option. They are after all in breach of their the terms of the contract.
I would make a complaint at JLR head office and copy the dealer in on it.
Post #508335 26th Feb 2016 7:32am
mcl001
Meant vehicles not 'be buckets!!'
Post #508336 26th Feb 2016 7:34am
I retro-fitted a heated screen to my Puma (County-spec so it didn't have one from new) and although there's a fair bit of work to do it properly it is entirely possible and well within the scope of a vehicle electrician or competent owner.
The heated screen is the second best modification I have made to the vehicle (I rate the VW99 variable vwipe relay as the best) and I simply would not be without it.
I can't comment on heated seats, but they are probably easier to retrofit (certainly no harder) than the screen.
Your dealer is fobbing you off, or simply doesn't want the work.
Post #508379 26th Feb 2016 10:25am
mk1collector
Mobile centre do a wiring kit for the heated screen and heated screens can be picked up off eBay or any windscreen supplier. Fcx do a wiring kit for the heated seats and lri solutions used to sell genuine heating pads for the seats. All are forum sponsors and any competent auto electrician should be able to fit them. Ray
My build thread
Post #508383 26th Feb 2016 10:41am
dgardel
Italy
Re: Cold weather package brand new 2016MY
THANKS
Ahhhrrgghh
Dealers, dealers...
I installed both on mine....
not so difficult....
Just Mk1 told
"1. Mobile centre do a wiring kit for the heated screen and heated screens can be picked up off eBay or any windscreen supplier.
2. Fcx do a wiring kit for the heated seats
3. LRI Solutions used to sell genuine heating pads for the seats."
Mind that the heated screen has 300-350 W (25 - 30 A) absorption, so you MUST install the right harness (8 - 15 mins. timed ON only when the engine is running) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #508397 26th Feb 2016 11:35am
Cupboard
Are there any relays that turn on when the engine starts rather than when the ignition is turned on?
Obviously you can fit a VSR but is there a nicer way of doing it?
Post #508423 26th Feb 2016 1:45pm
Martin
Site Admin
Yes, with the engine running signal that the instrument pack generates (on a Puma) or engine oil pressure switch signal (Td5 and earlier)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #508424 26th Feb 2016 1:49pm
