![]() | Home > Puma (Tdci) > Cold weather package brand new 2016MY |
AdrianCR Member Since: 23 Aug 2009 Location: Costa Rica Posts: 53 ![]() ![]() |
Picked up my new defender this month. it arrived without 2 options I ordered, heated seats and windscreen. The dealer refunded the option price, but I asked if these can be installed anyway by ordering the required parts. He told me , no the wiring is not there and would be difficult, then he told me I don't need them anyway because the seats don't heat very well, just a couple of wire strips in the bottom (its not like a range rover he said) and the windshield is mainly for arctic countries. I still want them but is the dealer correct on his points, that they will be difficult to retrofit and not work well anyway
THANKS SALLDHMR8GA488xxx is a XS model is not supposed to be standard thanks!!! ![]() ![]() This post has been edited by the site administration team: full VIN edited out |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
The seats don't heat very well? Is he serious?!!
Heated seats and windscreen. One of the few things on a Defender that work very well. Wouldn't want to be without them. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Heated seats and screen, were std fit for UK XS models California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
strange and this is the last one..
2 SPEAKERS FRT/2 SPEAKERS RR7.0X16 ALLOY ROAD WHL-STYLE 1110 INCH/2794MM WHEELBASE315 MHZ DOOR LOCK FREQUENCY3050 KG GVM @ 1250 FR/1850 RRAIR CONDITONING-MANUALALPINE HARD TOP-PLAINALTERNATOR-150 AMPAXLE DIFFERENTIAL - REAR 2 PINAXLE DIFFERENTIAL-FRONT 2 PINBADGE- REAR-DEFENDER-TITANBLUE TOOTH INTERFACE CONNECTBODY COLORED PAINTED ROOFBODYCOLOR WHEELLIP MLDGBRUNEL HEADLAMP MOLDINGSBUMPER UNDERRUN-FRONT-N2CARPET FLOOR COVERING-LEVEL 1CONSOLE-WITH CLOSED BINCORE DEFENDER CONSOLE MATERIALCOSTA RICADAY/NIGHT INSIDE MIRRORDIESEL FUEL CAPABILITYDOOR ENTRY REMOTE CNTR UNITDR HANDLES-INS MOLD IN BLACKDRIVER SEAT - STANDARDDRVR & PASS SEAT MAP POCKETSEBONY HEADLINERELECTRIC REAR WINDOW DEFROSTERENGINE POWER SOURCE - 122/360ENGINE TRACTION CNTRL BRK(DNU)EURO STAGE 4 EMISSIONSFOOT PEDAL DESIGN - STANDARDFRT BMPR-GLOSS BLK/GLOSS BLKGOODYEAR MTRGRILLE-BRUNELHALOGEN HEADLAMPSHIGHLINE ICEHOOD BADGE - DEFENDER BRUNELI/P INSERT - GRAPHITEINSTRUMENT PANEL -BASEINTR GRAB HANDLES - 6JACK-HEAVY DUTYKPH SPEEDOMETERLOCKING WHEEL LUG NUTMANUAL TELESCOPIC RADO ANTENNAMOLDED GEAR SHIFT KNOBMUD FLAPS - FRONTPASSIVE SEAT BELTS-FRONTPERIMETER /VOLUME THEFT SYSTEMPLASTIC HANDBRAKE GRIPPOWER FRONT SIDE WINDOWS PRIVACY GLASS PVC DOOR TRIM PANEL REAR DOOR POCKET STOWAGE REAR STEP ASSEMBLY REAR WINDOW WASHER/WIPER RR DR SPARE WHL CARR RR QTR VEN WDO-FXD SECURITY SIREN-BATTERY BACKUP SERAPHINITE/SCOTIA GREY SEVEN PASS SEAT CONFIGURATION SLIDING REAR SIDE WINDOW SOLIHULL ASSEMBLY (UK) SPANISH OWNER HANDBOOK #2 SPECIAL VALUE PACK E STABILIZER BAR-FRONT REAR STANDARD DUTY SUSPENSION STEP-SIDE RUNNERS STNG WHL-LEATHER WRAPPED T/TOW HTH-D/PLATE/BALL 7P TAILLAMPS-LEVEL 2 TRANSFER BOX - RATIO 1.2 VENTILATED DISC BRAKES WHEEL LOCKSTOP LESS BRAKE LIMITING VALVE LESS BULK HEAD LESS CARGO STOWAGE DEVICE LESS CHEQUER PLATES LESS CONTRAST STITCHING LESS DIM-DIP HEADLAMPS PACKAGE LESS ELECTR SPEED LIMITATION LESS FRONT FLOOR MATS LESS FRONT TOWING PIN LESS HALF DOOR LESS HEATED FRONT WINDSCREEN LESS HOODS LESS LOADSPACE COVER LESS MUDFLAPS-REAR LESS ROOF OPENING PANELS LESS SEAT TEMP CONTROL LESS SPARE TIRE COVER LESS TAILGATE LESS TOOL KITS LESS UNDERBODY PROTECTION LESS VEHICLE DECALS |
My retro fitted heated screen is used as much in our glorious moist summers as it is in the colder weather. Nothing worse than a misted up windscreen when it's warm and raining, as soon as you get inside with the kids all breathing and with wet coats the windows mist up allmost immediately, the heated screen comes into its own then
mcl001 Member Since: 14 Sep 2015 Location: Pembrokeshire Posts: 31 ![]() ![]() ![]() |
Agree with previous posts
Heated screen and seats are excellent Have had heated seats in various be buckets and are quicker and hotter than most such as Nissan Navara.(sorry for swearing on forum!) Personally I would not have accepted a refund of the option. They are after all in breach of their the terms of the contract. I would make a complaint at JLR head office and copy the dealer in on it. |
Meant vehicles not 'be buckets!!'
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
I retro-fitted a heated screen to my Puma (County-spec so it didn't have one from new) and although there's a fair bit of work to do it properly it is entirely possible and well within the scope of a vehicle electrician or competent owner.
The heated screen is the second best modification I have made to the vehicle (I rate the VW99 variable vwipe relay as the best) and I simply would not be without it. I can't comment on heated seats, but they are probably easier to retrofit (certainly no harder) than the screen. Your dealer is fobbing you off, or simply doesn't want the work. |
Mobile centre do a wiring kit for the heated screen and heated screens can be picked up off eBay or any windscreen supplier. Fcx do a wiring kit for the heated seats and lri solutions used to sell genuine heating pads for the seats. All are forum sponsors and any competent auto electrician should be able to fit them. Ray
Ahhhrrgghh Dealers, dealers... I installed both on mine.... not so difficult.... Just Mk1 told "1. Mobile centre do a wiring kit for the heated screen and heated screens can be picked up off eBay or any windscreen supplier. 2. Fcx do a wiring kit for the heated seats 3. LRI Solutions used to sell genuine heating pads for the seats." Mind that the heated screen has 300-350 W (25 - 30 A) absorption, so you MUST install the right harness (8 - 15 mins. timed ON only when the engine is running) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Are there any relays that turn on when the engine starts rather than when the ignition is turned on?
Obviously you can fit a VSR but is there a nicer way of doing it? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
Yes, with the engine running signal that the instrument pack generates (on a Puma) or engine oil pressure switch signal (Td5 and earlier)
