Home > Maintenance & Modifications > Chassis Cleaning Before Dinitrol
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
I'm slowly preparing my 2012 90 for a good dose of Dinitrol. I've got the chassis pretty clean and dry now but still want to go over it again to get it as clean as I can.
Will it be OK to use white spirit on a rag to wipe it over. Will this affect the Dinitrol? I think you can dilute some waxes (Waxoyl?) with a bit of white spirit so I hope it won't affect the Dinitrol.
I don't want to use a degreaser that you have to wash off as that means getting it wet again.
Post #504643 14th Feb 2016 6:24pm
Should be okay so long as it's fully dried off completely.
I just used water myself but then I did wait until peak summer when it was dry and warm.
Don't forget a rust cure such as Kurust before under seal if there are any corrosion areas.
Post #504648 14th Feb 2016 6:28pm
