Home > Td5 > Leaking fuel pressure regulator (2006)
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Hi Folks,
Finally traced a fuel leak to the back of my Fuel pressure regulator unit and was wondering if anyone had any issues with installing the cheaper non OEM units at all?
I have decided to replace the unit and overhaul the original at some future time for a spare - any thoughts or words of wisdom?
Regards
John
Post #503466 11th Feb 2016 2:42pm
mk1collector
You can get seal kits pretty cheap, a few on here have had success with them. Ray
My build thread
Post #503469 11th Feb 2016 2:53pm
Martin
Site Admin
I had zip-all success with a seal kit and fitted an OEM one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #503477 11th Feb 2016 3:19pm
RCMike
I went straight to fitting a new one and although the 3rd lower bolt is a PITA to get to, its not too bad. I elected to also change the front pipe as well, the nut on that is a real pig to get to (even with one of those crows feet sockets). So unless the front pipe joint is leaking, i'd leave that bit alone and just re use the old pipe.
Also, don't loose the little filter that can come out when you renew the o ring in the middle.
Post #503492 11th Feb 2016 4:15pm
JOHNT01670
cheers folks for the responses, think I will obtain a replacement OEM unit and leave the pipe in place as that is not leaking..
Many thanks!!
Post #503494 11th Feb 2016 4:22pm
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I fited a whole new FPR kit...but I would change only the O rings if I know it! Big Cry
Post #504193 13th Feb 2016 6:01am
windymiller
Much experience ..
DO NOT fit an after market !!! you will do it again a year later ,,genuine is circa £140 and you 1st one lasted 10 years ...
Don't say we didn't tell you .... Thumbs Up
Post #504196 13th Feb 2016 8:11am
srod
Took a punt on one of the £40 ones off ebay:
http://pages.ebay.com/link/?nav=item.view&...mp;alt=web
Had about 4000miles out of it so far, and seems to be holding up...
I guess if it fails I'll see it as a practice, and fit a genuine one!
Post #504214 13th Feb 2016 9:53am
JOHNT01670
Genuine FPR now fitted just need to repair the wires to the temperature sensor plug as I noticed they had become bared!!
Then bleed and test!!
hands will take longer to repair....
Post #506381 20th Feb 2016 12:51pm
