![]() | Home > Td5 > Leaking fuel pressure regulator (2006) |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
Hi Folks,
Finally traced a fuel leak to the back of my Fuel pressure regulator unit and was wondering if anyone had any issues with installing the cheaper non OEM units at all? I have decided to replace the unit and overhaul the original at some future time for a spare - any thoughts or words of wisdom? Regards John |
You can get seal kits pretty cheap, a few on here have had success with them. Ray
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
I had zip-all success with a seal kit and fitted an OEM one.
cheers folks for the responses, think I will obtain a replacement OEM unit and leave the pipe in place as that is not leaking..
Many thanks!! |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
I fited a whole new FPR kit...but I would change only the O rings if I know it!
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
Much experience ..
DO NOT fit an after market !!! you will do it again a year later ,,genuine is circa £140 and you 1st one lasted 10 years ... Don't say we didn't tell you .... ![]() |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Took a punt on one of the £40 ones off ebay:
http://pages.ebay.com/link/?nav=item.view&...mp;alt=web Had about 4000miles out of it so far, and seems to be holding up... I guess if it fails I'll see it as a practice, and fit a genuine one! |
Genuine FPR now fitted just need to repair the wires to the temperature sensor plug as I noticed they had become bared!!
Then bleed and test!! hands will take longer to repair.... |
