Home > Technical > decat and mot
foxing
Wales
decat and mot
is there a test on the mot for a cat or is it just a visual?
atb paul
Post #501670 7th Feb 2016 2:26pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Diesel engine have a "smoke" test, this checks the density of the smoke when accelerated at max revs. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #501675 7th Feb 2016 2:31pm
K9F
Visual check to see if it's there. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #501684 7th Feb 2016 2:50pm
Visual only, there's a very good chance they won't notice if they're not Defender specialists.
Post #501873 7th Feb 2016 9:55pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Yep, two MOT's since decatting my 110 Puma and no problems at the test Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #501877 7th Feb 2016 9:59pm
K9F
You could always modify your decat pipe if you have the means?
Post #501941 7th Feb 2016 11:56pm
foxing
Wales
my mot isn't due for a couple of months just thinking ahead,i have a dummy cat fitted so hopefully i'll have no problems
atb paul
Post #501973 8th Feb 2016 6:27am
