![]() | Home > Technical > decat and mot |
foxing Member Since: 20 Sep 2008 Location: south wales Posts: 80 ![]() ![]() |
is there a test on the mot for a cat or is it just a visual?
atb paul |
Diesel engine have a "smoke" test, this checks the density of the smoke when accelerated at max revs. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Visual check to see if it's there. If you go through life with your head in the sand....all people will see is an ar5e!!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17812 ![]() ![]() ![]() |
Visual only, there's a very good chance they won't notice if they're not Defender specialists.
You could always modify your decat pipe if you have the means?
![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
my mot isn't due for a couple of months just thinking ahead,i have a dummy cat fitted so hopefully i'll have no problems
atb paul |
