![]() | Home > Puma (Tdci) > 2007 2.4 tdci not revving. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Sounds like EGR getting stuck open, once warm it frees up.
When was the fuel filter last changed also? |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 ![]() ![]() |
Went to BLRC and they removed some gunk from the sender unit in the fuel tank. Time will tell if this was the problem but so far so good.
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
Lovely truck, I really like it.
First of all i would clean MAF and MAP-Sensor. If you have/had EGR-Problems especially the MAP-Sensor might be dirty. Be careful when cleaning. Does the truck start normally (quickly)? There might be also an CHT-Sensor issue. At cold starts and low CHT-Temperatures, the ECM raises the amount of fuel because of the fuel-"loss" due to cold cylinder temperatures where an amount of fuel condensates. CHT als is responsible for the time the glow plugs are on. It might be worth checking these things. |
Hornet,
Thank you for your kind words re my Defender - much appreciated. I went out this morning and took her for a drive and the problem did not appear. The guys at my local independent (BLRC) - top lads by the way - said that problems with the puma could be difficult to identify even with the computer plugged in. The gunk they removed I think is a reaction between the diesel and the plastic fuel tank - they said it never used to happen with metal tanks. It always did start ok so fingers crossed the problem is licked. Thanks again. Mobilesawmiller. |
We call it "Dieselpest". Check with google if your gunk looks similar. Often happens to vehicles with extremely low milage. I do not think it has anything to do with the material of the tank. Might be worth thinking about a appropriate biocide to prevent anytrhing in future...
Thanks Hornet.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18030 ![]() ![]() ![]() |
It is the result of the biological components in modern diesel, and is a microbial growth. In order to reproduce the microbes need oxygen which comes from the condensate which is inevitably present in fuels. The longer the fuel has stood around (whether in a storage tank at a filling station or in a can in your workshop) the more likely you are to have problems.
Some while back I had major issues as a result of this problems (see this thread). Also from another thread:
It is also worth noting that in the vast majority of cases any significant fuel contamination issues (whether water, dirt, or the diesel bug) will result in VCV damage and the need to replace the VCV. |
Thanks again lads. My next issue was an oil leak from the near side of the engine. It appeared to be coming from higher up. First suspect was the vacuum pump so my local mechanic fitted a new gasket - did not cure the leak. I took the Defender down to BLRC on Saturday morning. The lads suspected a cracked vacuum pump but it turned out to be OK. Next on the list was to replace the gasket on the water pump. They also found one of the injectors to be slightly loose - apparently air can be sucked in and cause a bit of pressure which can result in the odd oil leak. I drove the 40 or so miles home and the leak seems to be 95% cured. I will keep an eye on this to see how things go. Must admit I am a bit disappointed so far - my last tdci was a 2008, bought with 25,000 miles and sold after 2 1/2 years with 80,000 on the clock. Apart from replacing the EGR valve 3 times it ran like a clock. Anybody else out there with a similar oil leak?
Mobilesawmiller. |
