Home > In Car Electronics > CCTV Monitor Power Supply
discomog
I am about to fit a couple of cctv cameras to my horse trailer, one internally for viewing the horses whilst travelling and the other externally as a reversing camera behind the trailer. I am looking to mount the monitor on the parcel shelf below the passenger grab handle. The monitor requires an ignition fed 12 volt supply, maximum current draw 1.2 amps. Can someone recommend where I can tap into an existing cable, preferably somewhere that doesn’t require me to strip down half the dashboard. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #500210 4th Feb 2016 9:33am
excossack
I would consider a switch and a direct feed off the battery. That way you can keep an eye on the horses when you are parked up? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #500361 4th Feb 2016 1:18pm
Eduardo
discomog
For the internal camera, you can take it from the live socket at the rear in the rigth side of the defender (the same that some of us used to install a 12V socket). For the reverse one I use the feed of the reverse ligths.
Cheers Eduardo
Post #500375 4th Feb 2016 1:41pm
