![]() | Home > Puma (Tdci) > Are EGR and MAF error codes related? |
On the way to the Defender tour yesterday, my 110 went in to limp along, which was a bit annoying. Although it can still quite happily cruise at 70 on the flat and 60 up reasonably steep hills so isn't that much of an issue. Last time it did that was on the way home from the LRO show so I think it's embarrassed to see other Land Rovers
![]() Anyway. The faults showing according to my IID Tool were:
Now most of those are always there and I know 1103, the MAF one, is a common nuisance. These are the "tested" list rather than including the untested ones. If I've understood the menu correctly. I cleared them all, tootled off up the road but after 15-25 miles it would go back in to limp, sometimes with the fault light on, more often without. The codes that keep coming back (according to the Ultragauge I have fitted) are 1103 and 0234. I haven't put the IID Tool back in again to see what else is there. Sometimes the Ultraguage would bleep that there was a fault, but that didn't always seem to coincide with a loss of power. It would seem to happen when under fairly light load, it never died whilst I was overtaking something, I'd just come to put my foot down and nothing much would happen. Other symptoms... bit of white smoke on a cold start and slightly lumpy idle until warm. Dead spot under hard acceleration around 2300RPM. Clattery under light load when cruising. Sounds sweet as anything if you put your foot down though. Sometimes runs a lot less clattery than others. Nasty above 2900RPM but I'm not sure that's a fault! Is it a take it in to a garage job? Get a remapper to remove the EGR? New MAF sensor? Give it to Caterham? Thanks in advance. |
MIL keeps coming back now, but it's not limping any more.
I've done a load more reading, and think my next course of action is a replacement MAF, then if that doesn't fix it blank the EGR, and if that make it drive better I'll get BAS to remove it. The Britpart MAF is listed as "OEM" and is 1/3 the price of a genuine one. Does the fact it's cheap mean it's rubbish, or the fact it's "OEM" mean it's OK? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20872 ![]() ![]() |
Do you have an OE factory map with working EGR?
Britpart stuff is always going to be chancy. Steve.
OE factory map yes. Working EGR, I think so! It does the 5 chukkas, so long as the error codes haven't come up (and they haven't since Monday) the UG is reporting it's values changing. Monday I had repeated error codes of 0234 and 1103 with occasional 0404 but rarely the MIL light. Since then I've had the MIL more, but only the 1103 codes and no limp. The flip side is that whilst I've done plenty of miles this week, I haven't done any motorway miles because we don't have them in Norfolk! Still the short stretches of dual carriageway we do have has been fine (saving the light and 1103). I've read through all the posts I can find on EGR and MAF, and be the sounds of things a dodgy MAF will affect lots of other things. I've sent Duckworths a PM about a new MAF and some other stuff, so waiting to hear pricing there. |
I'm certainly not going to spend money on a new EGR, that would seem silly!
Thing I don't get is that it used to be £30-40, it's now more like £100. This thread has been helpful: http://www.defender2.net/forum/topic8876.html
Interesting reading, my MAF could do with changing due to age.
I know what you mean about the prices, they were about £150 a couple of years against and it's even more now. The part which I cannot understand is I thought the very purpose of the system was for fault detection and to improve the quality of running of the engine. Not to have one item with an issue affect another electronically and make it look like another issue all together. The completely defies the logic of it's purpose to flag and diagnose some faults. Makes it somewhat an expensive game of Russian Roulette of swapping parts that may be at fault. The P1103 as K9F suggests is nothing but a pest, one that I haven't personally suffered from but is nothing more than a nuisance. I'd stick with it for now and see how it goes, if it keeps it up on a permanent basis then it's time to take action. It may sort it's self out after multiple driving cycles. |
"Mechanical failure - actuator is stuck closed" isn't this possibly the root cause of the other issues?
^^^^ That's what I was thinking, it suggests the EGR is stuck closed.
Better than being stuck open or there would be bigger problems if that was the case. This is exactly what I had when it was doing this before I got a map. I hoped it would sort it's self out after a while, it didn't it stayed on permanently until I changed EGR. And then with a new one a year or two later it started again, seriously hacked off be then and went down the Remap route. Best choice I made. |
It could be the EGR, I don't know.
From what I've read since my first post, and I thought I'd read quite a lot before posting, they both cause problems with each other. What's putting me more towards the MAF is that's the code that keeps coming back is the MAF one. It's had MAF error codes before, a few months ago, which then went away again. That's not to say there's nothing suggesting it's the EGR either though! One thing I don't understand is the relationship between limp, warning lights and error codes. You can have tested DTCs logged but no sign of them, you can have limp but no warning light, warning light but no limp, and both together. On Monday I had one occasion were the lamp came on and loads of limp mode. During the week I've had the lamp (despite being reset it kept coming back) but no limp, then Friday and Saturday no pending codes, no tested codes, no limp, no light. Those two days I haven't been far, maybe 60 miles, but the engine has warmed up properly and had some short and some longish runs. |
MAF will always come back as it's monitoring other things and so symptomatic. The reading you are getting is higher but within range - that means that the MAF is actually working.
I'd start with the error code that lets you know something is actually wrong - the stuck actuator. This may of course be intermittent and only stick when it gets driven to the extreme of it's range. |
Another thing I used to notice and dome thing you can't always help, it's prone to getting stuck more in cold weather.
It can get stuck permanently, luckily in this case closed and not open. And last but not least lots of short trips seems to Coke them more and they play up more. As above, my money is on the stuck EGR. This is putting MAF readings out as well as general performance, but the MAF is working. I'd suggest either new EGR or remap. The latter is a permanent fix. |
What about taking it off for a clean - just seeing if it's clogged first and then if you can bench test it to see if it moves freely through it's full range?
Are the actuators replaceable on their own or is it a complete unit swap? |
AFAIK, LR sell complete units only, no parts.
Part and partially (pardon the pun) due to the likelyhood of cleaning not being a suitable fix. Some people seem to get very little EGR trouble for years, others lots of it even after changing the dammed things. |
