Home > Maintenance & Modifications > Anyone installed a Safety Devices 'Style Bar?'
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Thinking of fitting one of these or something similar, has anybody fitted one - are they difficult to fit and general thoughts please?
Post #492910 16th Jan 2016 12:48pm
ibexman
Without internal hoop it would only be cosmetic!
Post #492913 16th Jan 2016 12:55pm
camelman
As ibexman says, the external hoop mounted to the body would be for looks only as there is no structural benefit.
On my last hard top I went for the SD cab protection cage which has the internal hoop behind the driver and then external over the front roof and screen.
Post #492915 16th Jan 2016 1:15pm
Lambley
Cosmetic only is fine, I'm not after more protection just looks cool to me Very Happy
Post #492951 16th Jan 2016 4:24pm
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
I considered putting one on my wifes 90 but she wants a Massai style roof rack and it won't fit with one of those.
Post #492954 16th Jan 2016 4:37pm
Sailingtom had one on his td5, you might drop him a PM ?
Post #492955 16th Jan 2016 4:51pm
g-mack
Do they do a set up like this for the 5 door csw? My 109 thread
my youtube channel
Post #492968 16th Jan 2016 5:36pm
Lambley
i will do, thank you.
Post #492981 16th Jan 2016 6:16pm
CarMan
I like the look at that - do you have a price? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #492993 16th Jan 2016 6:33pm
camelman
Yep, have a look at www.safetydevices.co.uk and go to the expedition tab.
Post #493009 16th Jan 2016 6:53pm
Lambley
Looks like there's 2 in the range - one looks like it's thicker and in silver only (RBL2303SSS) at £588, the other is black and is a bit cheaper (RBL1383SSS) at £545 (from Paddocks)
I guess I'll have to make some enquiries on Monday, the silver one looks better and thicker but I would have to get it powder coated black which I'd guess at an extra £50?
[URL=][/URL]
Post #493010 16th Jan 2016 6:57pm
Alex1976
I have the style bar on my 90. I bought it second hand and it came off a G4 style defender, so it was a genuine LR product, although I believe they are made by Safety Devices for LR.
It was easy to fit, I decided to fit it using large rivnuts so I could bolt it in without having to get to the inside of the wings/roof with a nut and spanner.
I used stainless steel socket head bolts to mount it and coated them in Dynax wax first to help prevent bimetallic corrosion and also seal the bolts to stop water ingress.
I feel that apart from the cosmetic benefits it also adds some rigidity to the body. Well it feels as if it does.
Post #493045 16th Jan 2016 8:53pm
Lambley
Cheers Alex, sounds good advice to me, any pictures?
Post #493050 16th Jan 2016 8:59pm
Alex1976
I can take a couple in the morning and post them on here for you.
Post #493062 16th Jan 2016 9:23pm
Lambley
That would be great, thanks. One question - does it limit visibility around the screen at all?
Post #493074 16th Jan 2016 9:43pm
