![]() | Home > Maintenance & Modifications > Anyone installed a Safety Devices 'Style Bar?' |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Without internal hoop it would only be cosmetic!
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
As ibexman says, the external hoop mounted to the body would be for looks only as there is no structural benefit.
On my last hard top I went for the SD cab protection cage which has the internal hoop behind the driver and then external over the front roof and screen. ![]() Click image to enlarge ![]() Click image to enlarge ![]() |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Cosmetic only is fine, I'm not after more protection just looks cool to me
chrispy Member Since: 14 Mar 2015 Location: Gwent Posts: 347 ![]() ![]() ![]() |
I considered putting one on my wifes 90 but she wants a Massai style roof rack and it won't fit with one of those.
Sailingtom had one on his td5, you might drop him a PM ?
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
Do they do a set up like this for the 5 door csw? My 109 thread my youtube channel |
i will do, thank you. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1893 ![]() ![]() |
I like the look at that - do you have a price? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Yep, have a look at www.safetydevices.co.uk and go to the expedition tab.
Looks like there's 2 in the range - one looks like it's thicker and in silver only (RBL2303SSS) at £588, the other is black and is a bit cheaper (RBL1383SSS) at £545 (from Paddocks)
I guess I'll have to make some enquiries on Monday, the silver one looks better and thicker but I would have to get it powder coated black which I'd guess at an extra £50? [URL=] ![]() [/URL] [URL=] ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I have the style bar on my 90. I bought it second hand and it came off a G4 style defender, so it was a genuine LR product, although I believe they are made by Safety Devices for LR.
It was easy to fit, I decided to fit it using large rivnuts so I could bolt it in without having to get to the inside of the wings/roof with a nut and spanner. I used stainless steel socket head bolts to mount it and coated them in Dynax wax first to help prevent bimetallic corrosion and also seal the bolts to stop water ingress. I feel that apart from the cosmetic benefits it also adds some rigidity to the body. Well it feels as if it does. |
Cheers Alex, sounds good advice to me, any pictures?
I can take a couple in the morning and post them on here for you.
That would be great, thanks. One question - does it limit visibility around the screen at all?
