Home > Puma (Tdci) > Swapping Glow Plugs
Page 2 of 2 <12
Caterham
it would be but I don't think there's any faults being logged. I don't think they record everything
Post #493206 17th Jan 2016 11:41am
dorsetsmith
Caterham wrote:
Shocked
thought I'd just 'pop' out and check the glow plugs, small socket set, multi-meter and 10 minutes should do.
F ' in aida - I think I might need to set a day aside in the summer. I'm guessing the only chance of doing that is inlet manifold off?
with the chance of snapping a glow plug off I'm wondering if installing a webasto type diesel heater might be easier and do away with the need for glow plugs plus all the other benefits.....and if a plug does snap off could prove cheaper overall?
test them in place just remove connector from the glow plug and use multi-meter on one at a time prox 0.6 ohm for good reading Exclamation
Post #493208 17th Jan 2016 11:43am
Caterham
that was my intention but I'm not sure how possible / practical that is with the inlet manifold in place?
have you tried yourself or is that a theoretical suggestion?
either way thanks for the comment.
Post #493210 17th Jan 2016 11:53am
Have you seen the number of different dtcs there are for the glow plug system in total?
I think a scan tool will get you the answer you are looking for without even having to open the bonnet.
Post #493241 17th Jan 2016 1:23pm
martinfiattech
Why not check for current draw thru the circuit. about 60 amps total from stone cold. =15 amps per glow plug.
Once they`ve been used they drop to 40 amps (ish) 8 to 10 amps.
As long as there 12 volt ones. some run at 3.5 volts now, but that's mostly cars. Excuse the spelling I`am better with spanners and wires.
Post #493456 17th Jan 2016 10:15pm
dorsetsmith
long nosed plis you can remove the connector
Post #493468 17th Jan 2016 10:23pm
dorsetsmith
Post #493471 17th Jan 2016 10:23pm
dorsetsmith
double post
Post #493472 17th Jan 2016 10:24pm
Caterham
Long nose pliers next week then. Thumbs Up
Post #493491 17th Jan 2016 10:53pm
Page 2 of 2 <12
