Home > Puma (Tdci) > Slight over rev when changing gear & in Low range
Homra
2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hello All,
I have recently bought a 90 station-wagon puma, past defenders have been 200, 300 series and TD5 so this is my first puma.
I use the landie for towing 80% of the time 3.5/4 ton.
I have noticed when changing gear mostly in lower gears when i clutch and change gear the revs do not drop of but do the opposite a slight jump circa 100 or 200 revs.
When in low range especially when im reversing trailer, when i want to find the biting point of clutch for accurate maneuvering the engine will rev up on her own accord. I assume this is some form of anti stall business!! but it is frustrating when i do not touch the accelerator the vehicle revs and i then need to clutch etc
I hope this makes a bit of sense. I basically want to know is this the way this puma drives or is there a download etc to sort?
I also would like some advise on a good tune for towing.
Many thanks Jeremy
Post #43312 22nd Oct 2010 7:57pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
In low first the revs rise to about 1000 and stay there, even trying to slow it a bit on the brakes don't work, it just keeps on going. I must admit it does make super-slow manouvering quite hard work.
Post #43336 22nd Oct 2010 11:49pm
AndrewS
Its called the Idle Jack.
Search +idle +jack Thumbs Up
http://www.defender2.net/forum/topic1177.html?highlight=idle+jack
http://www.defender2.net/forum/topic423.html?highlight=idle+jack 130's have feeling's as well you know Smile
Post #43344 23rd Oct 2010 8:24am
jst
idle jack, to overcome the low speed in 1st low which LR deemed was too slow. takes it upto 1100rpm. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #43475 25th Oct 2010 2:05pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
In addition to anti stall and throttle ramp in low-range, mine (2008) had the same issue in high-range. I understand this was achieved using a switch on the clutch to increase revs between gears to reduce transmission shunt - it didn't really work too well and made it sound like I couldn't drive properly Laughing
Successive clutch upgrades and maybe newer engine management patches over the last 2 years, and it doesn't do it any more - I wondered what year is your Defender? 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #44170 2nd Nov 2010 5:30pm
Homra
mine does the same in high range, like you say as if you don't take your foot off the acelator to change gear, mine is 2010
Post #44916 10th Nov 2010 10:15pm
