![]() | Home > Maintenance & Modifications > Galvanise or not to Galvanise |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20927 ![]() ![]() |
You can Galv and then paint if you like. Go for it as it is off if you can.
I would but I'd have to go through the faff of removing, galving and then paining most of the issue in removing. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
http://www.paddockspares.com/dinitrol-clas...e-car.html
Dinitrol everything in stead??? |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
I have some Dinitrol as well, which I will be using inside the box sections and on the underside of the x-member.
Given January is likely to be a wet/cold/possibly snowy month Galv will be some decent protection until summer comes and I can apply some paint. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Little point if its the only to ng galvanised. Paint and protect.
Little point if its the only to ng galvanised ? 1999 Defender TD5 110
Triggers broom - the rest can follow in time...
Indeed. Ideally a new chassis, but not enough money in the pot for that. 1999 Defender TD5 110
