Home > Maintenance & Modifications > Galvanise or not to Galvanise
excossack
Just purchased a Blacksheep X-member and before having it fitted, I am toying with the idea of having it galvanised.
I know some of the galvanise coating will have to be ground off when weldeing, but it seems a more durable finish than say painting it? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #484665 22nd Dec 2015 11:16pm
You can Galv and then paint if you like. Go for it as it is off if you can.
I would but I'd have to go through the faff of removing, galving and then paining most of the issue in removing.
Post #484669 22nd Dec 2015 11:20pm
ickle
Post #484679 22nd Dec 2015 11:40pm
excossack
I have some Dinitrol as well, which I will be using inside the box sections and on the underside of the x-member.
Given January is likely to be a wet/cold/possibly snowy month Galv will be some decent protection until summer comes and I can apply some paint. 1999 Defender TD5 110
Regards
John M0VAZ
Post #484732 23rd Dec 2015 9:39am
T1G UP
Little point if its the only to ng galvanised. Paint and protect.
Post #484743 23rd Dec 2015 10:15am
excossack
Little point if its the only to ng galvanised ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #484753 23rd Dec 2015 10:40am
Triggers broom - the rest can follow in time...
Post #484777 23rd Dec 2015 12:13pm
excossack
Indeed. Ideally a new chassis, but not enough money in the pot for that. 1999 Defender TD5 110
Regards
John M0VAZ
Post #484817 23rd Dec 2015 2:51pm
