Home > Maintenance & Modifications > RR Evoque seats in 2004 110
Baklengs
Norway 2004 Defender 90 Td5 SW Java Black
Just completed fitting seats from a Evoque in my Defender. Fantastic comfort and looks great as well. Front seats where pretty straight forward, rear seats took a bit of welding and fabrication, but they are definetly worth the effort! If you have small children you also get the benefit of isofix Smile been watching ebay for a while and you usually get the complete set of five seats for £500-£1000 so its quite good value for money.
Post #477503 29th Nov 2015 10:28pm
grumpy old git
Top job there 👍
Post #477507 29th Nov 2015 10:40pm
SailingTom
Really nice 10/10 look better than the recaros as you have matching rears to complete Thumbs Up
Post #477509 29th Nov 2015 10:42pm
Baklengs
Thanks! Yes, the matching front and rear lifts the impression. Another benefit is that there is now quite a bit of room under the seats so I have been able to hide two amplifiers, a 12" subwoofer and a 10kw isotherm heater for the cold days here up north. The heater has 4 vents so I am distributing the air out on both sides of the rear seats up towards the windows and two vents out in front of the rear seats. This gives a really good airflow and a good and warm car. Helps demisting the windows aswell.
Post #477518 29th Nov 2015 11:03pm
excossack
Re: RR Evoque seats in 2004 110
Baklengs wrote:
Is it that bad in Bærum you need bars on the passenger window Smile 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #477519 29th Nov 2015 11:05pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Looks good. Won't the front seats make you sit very high?
Post #477521 29th Nov 2015 11:05pm
Baklengs
excossack wrote:
Polar bear protection Whistle
You sit a bit higher than with the original seats, but I had risers on my seats earlier and it's quite similar to that.
Post #477525 29th Nov 2015 11:10pm
tomdaprince
Netherlands 2007 Defender 90 Puma 2.4 HT Tonga Green
Looks awesome1 How and where did you obtain the seats?
Post #477570 30th Nov 2015 9:25am
Baklengs
Thanks! Bought them off ebay for £450 and paid a small fortune to ship them to Norway Smile
Post #477576 30th Nov 2015 9:43am
Bristol 90XS
How hard were the front ones to fit? Have recaros now with risers, will they fit directly or is there and metalwork needed?
Thanks
James
Post #477583 30th Nov 2015 10:41am
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
Great installation! Looks like a lovely job.
How did you fit and secure the front seats? Also, do they have power adjust and heated elements? If so, are you using them? Sandy
Post #477584 30th Nov 2015 10:43am
Baklengs
The seats are a bit wider than the original ones, but the mounting holes match up on one side and then you have to drill out the two opposite holes and use a piece of metal to reinforce the mounting underneeth the car. Easy job. I've got the heater elements working, but still fiddeling with the electric seat adjustment. Will figure it out eventually, but the seats are also manually adjustable so this really isen't a problem.
Post #477590 30th Nov 2015 11:21am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Looks great. But how do you get to your batteries now?
As in The Netherlands the MOT man wants to see if the batteries are secured well. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #477667 30th Nov 2015 3:32pm
Baklengs
I,ve put in an anderson plug for charging etc, but the acccess down to the batterie is now only possible if by removing the seat. Luckily I know my local MOT guy so that want be a problem Smile
Post #477718 30th Nov 2015 5:47pm
