![]() | Home > Maintenance & Modifications > RR Evoque seats in 2004 110 |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
Top job there 👍
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Really nice 10/10 look better than the recaros as you have matching rears to complete
Baklengs Member Since: 13 Apr 2014 Location: Bærum Posts: 11 ![]() ![]() ![]() |
Thanks! Yes, the matching front and rear lifts the impression. Another benefit is that there is now quite a bit of room under the seats so I have been able to hide two amplifiers, a 12" subwoofer and a 10kw isotherm heater for the cold days here up north. The heater has 4 vents so I am distributing the air out on both sides of the rear seats up towards the windows and two vents out in front of the rear seats. This gives a really good airflow and a good and warm car. Helps demisting the windows aswell.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6006 ![]() ![]() ![]() |
Is it that bad in Bærum you need bars on the passenger window ![]() Regards John M0VAZ Econet Station 48 no clock |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Looks good. Won't the front seats make you sit very high?
Polar bear protection ![]() You sit a bit higher than with the original seats, but I had risers on my seats earlier and it's quite similar to that. |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 ![]() ![]() ![]() |
Looks awesome1 How and where did you obtain the seats?
Thanks! Bought them off ebay for £450 and paid a small fortune to ship them to Norway
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
How hard were the front ones to fit? Have recaros now with risers, will they fit directly or is there and metalwork needed?
Thanks James |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315 ![]() ![]() ![]() |
Great installation! Looks like a lovely job.
How did you fit and secure the front seats? Also, do they have power adjust and heated elements? If so, are you using them? Sandy |
The seats are a bit wider than the original ones, but the mounting holes match up on one side and then you have to drill out the two opposite holes and use a piece of metal to reinforce the mounting underneeth the car. Easy job. I've got the heater elements working, but still fiddeling with the electric seat adjustment. Will figure it out eventually, but the seats are also manually adjustable so this really isen't a problem.
Looks great. But how do you get to your batteries now?
As in The Netherlands the MOT man wants to see if the batteries are secured well. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I,ve put in an anderson plug for charging etc, but the acccess down to the batterie is now only possible if by removing the seat. Luckily I know my local MOT guy so that want be a problem
