Home > Td5 > Clutch advice please
highbayrack
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
We (SWMBO) have had our 110 from new, so it's getting on for 8 years old now with no major problems in 60k miles. Recently the wife has complained a couple of times of problems getting the car into gear. I drove it the other day and it happened to me, I tried to change up and it just wouldn't go in. The only way it would go in was to depress the clutch, then try again. I'm guessing the clutch/trust bearings are on the way out.
Would appreciate any advice please on what you think the problem might be.
Chris Thumbs Up MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
Post #42219 7th Oct 2010 8:22pm
landy andy
Have tried changing the oils?
Would recommend the difflock oils, often when cold gears are hard to get.
My clutch lasted over 100thou hard miles. So 60 is low for a clutch.
Andy
Post #42221 7th Oct 2010 9:09pm
highbayrack
Good point Andy, i'll get them checked at a local independant tomorrow, Thanks Thumbs Up MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
Post #42222 7th Oct 2010 9:19pm
landy andy
If you are getting them done for you, make sure they use MTF not ATF or EP Thumbs Up Thumbs Up
Would just get them changed rather than checked, as is the cheapest place to start Mr. Green
Andy
Post #42224 7th Oct 2010 9:25pm
highbayrack
Cheers mate. he's a good guy so i'm sure he will put me right if he can fit me in tomorrow. MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
Post #42225 7th Oct 2010 9:32pm
