![]() | Home > Td5 > Clutch advice please |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Have tried changing the oils?
Would recommend the difflock oils, often when cold gears are hard to get. My clutch lasted over 100thou hard miles. So 60 is low for a clutch. Andy |
| highbayrack Member Since: 06 Feb 2009 Location: Northampton Posts: 31
Good point Andy, i'll get them checked at a local independant tomorrow, Thanks
If you are getting them done for you, make sure they use MTF not ATF or EP
Would just get them changed rather than checked, as is the cheapest place to start Andy |
Cheers mate. he's a good guy so i'm sure he will put me right if he can fit me in tomorrow. MY02 Defender 110 CSW air con, electric windows, privacy glass, traction control, abs,tow pack, parking sensors,rai,special rear seat conversion.
