![]() | Home > Td5 > Slight vibration on acceleration. |
back prop shaft UJ easy to check look for rust or play in the uj
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
What dorsetsmith said except check both front and rear prop shafts. They can be sneaky... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Crank pulley, when you switch the engine off listen out of the window for a sort of chirp noise. Ray
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
I haven't heard any kind of chirp noise upon turning the engine off, so i'll book it in the get the front and rear universal joints done then see how it is after. Thanks
