Home > Td5 > Slight vibration on acceleration.
TOP5N
When i accelerate hard, in the higher rev range it feels like i am going over a rumble strip... Not sure if this is just a defender thing due to the amount of running / drive gear, or whether i have something that is worn out...
Chris
Post #475587 23rd Nov 2015 9:17pm
dorsetsmith
back prop shaft UJ easy to check look for rust or play in the uj Exclamation
Post #475593 23rd Nov 2015 9:35pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
What dorsetsmith said except check both front and rear prop shafts. They can be sneaky... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #475636 23rd Nov 2015 10:53pm
mk1collector
Crank pulley, when you switch the engine off listen out of the window for a sort of chirp noise. Ray
My build thread
Post #475640 23rd Nov 2015 10:59pm
TOP5N
I haven't heard any kind of chirp noise upon turning the engine off, so i'll book it in the get the front and rear universal joints done then see how it is after. Thanks
Post #476147 25th Nov 2015 7:53pm
