Home > Maintenance & Modifications > Poor Brakes on Defender TD5
Page 2 of 2 <12
Freddie
South Africa 2004 Defender 110 Td5 USW Bonatti Grey
Hi Simon,
Please let me know whether they solve your issues.
Beyond the ideas in the other thread, brake fade to me would suggest that your rotors/ pads are getting hot. Since putting grooved and vented disks on my Overland Vehicle, which is pretty hefty, I have yet to experience brake fade. If anything the hotter they get the better they work.
It also has wheel spacers which I put on to assist with stability but I'd bet that they also improve air flow around the disks.
Maybe worth a look if the hoses don't make much difference and it still bothers you.
Post #469633 5th Nov 2015 8:45am
teek
I realize a very old thread, but I now have this exact problem. Was there a resolution?
Teek - 1999 Derender 110 Td5 in Canada
Post #992472 13th May 2023 12:31pm
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
I had a similar problem, turned out to be a small leak in the vacuum hose to the servo. The brakes worked fine and there was some power assistance but it was weak, you had to really push, and there was no 'bite'. Much better with a new piece of hose.
Post #994344 28th May 2023 11:01pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
I recently replaced my brakes, rotors, pads and calipers on my 2000 TD5 with the Alive setup having had ongoing problems with poor brake performance
It is now very good and progressive. I would recommend looking at this setup.
TC
Post #994346 28th May 2023 11:24pm
Page 2 of 2 <12
