Home > Maintenance & Modifications > Welding a Td5
shaggydog
Welding a Td5
Hi Guys,
I'm hoping to get a bit of a work party going this weekend to finally knock the 200tdi problems on the head and to start sorting some issues on the Td5.
One of them being the rear door needs some welds as its cracking a bit.
I have never had to remove the battery on a Td5 before so whats the procedure?
I don't want to cause any problems with the immobilizer or alarm module Embarassed Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #467826 30th Oct 2015 1:54pm
For the sake of 6 bolts, I'd take it off the hinges? Be easier to weld on as well?
Post #467829 30th Oct 2015 2:01pm
excossack
Done welding in a TD5 on all the front doors and rear x-member, Never removed battery. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #467831 30th Oct 2015 2:03pm
shaggydog
True but I fear it may need remedial work to allow it to come off the hinges in 1 piece Laughing
Really?
I was told you always had to undo the battery when welding on a vehicle or it can cause it to explode Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #467832 30th Oct 2015 2:05pm
excossack
Really.
I guess end of the day, its your call. 1999 Defender TD5 110
Regards
John M0VAZ
Post #467839 30th Oct 2015 2:20pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Not so much battery, but alternators, airbags, and ecu are a bit sensitive to spikes.
Always disconnect battery when welding.
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #467843 30th Oct 2015 2:31pm
Cupboard
All our tractors have a big sign saying words to the effect of "isolate battery and put earthing clamp as close as possible to where you're welding".
Not to say anything will go wrong, but they less chance you have of killing electrics the better.
You could always gas weld Rolling with laughter
Post #468076 31st Oct 2015 1:26pm
T1G UP
pull the neg on the battery, thats then isolated.
as for the rear door i'd take it off, take the skin off and repair
Post #468087 31st Oct 2015 2:05pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Disconnect the ecu multi plugs too. The ecu on a td5 is earthed through the drivers seat box, I have had to replace two that have been blown by other garages carrying out welding work.
Post #468148 31st Oct 2015 7:16pm
shaggydog
Thanks for all the comments guys Bow down
In the end we took the rear wheel off the back door and stripped it down and decided to just go without the spare for now so I'm making up a plate at work tomorrow to fit and then will get a spare wheel carrier to take the weight.
Then in time will replace the door as the door skin is well past saving Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #469559 4th Nov 2015 10:55pm
