Home > Wheels & Tyres > Offset question
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
Offset question
Hi can someone please tell me what the offset is for the factory heavy duty steel wheels?
Cheers,
Ant
Post #463420 15th Oct 2015 10:34am
From http://www.defender2.net/forum/topic35064.html
blackwolf wrote:
Offsets:
HD steel wheels ("Wolf") +20.6mm
Sawtooth +20mm
Deep Dish +33
Freestyle +33
Standard LWB steel +33
Boost +33
Disco 1 standard steel +20
Post #463431 15th Oct 2015 10:56am
GypsySamuraiAnt
Thanks mate Thumbs Up
Post #463433 15th Oct 2015 10:59am
GypsySamuraiAnt
Sorry just confirming they are 16x7's?
Post #463436 15th Oct 2015 11:04am
K9F
It will be HD steel Wolfs listed above but they could be 16 X 7.5. You may need to examine the markings carefully. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463456 15th Oct 2015 12:17pm
Assuming that they are genuine, they'll be 6.5 J 16.
Spec:
Width 6.5"
Profile J
Diameter 16"
Offset +20.6 mm
Load rating 2200 Kg
Studs 5
PCD 165 mm
Part Number ANR5593 (Tube type), ANR4583 (Tubeless)
The only 7"x16" steel rims LR has ever made are Disco1 standard steels (NTC5193) and P38/Disco2 standard steels (RRC114560MUW) although the latter is of course on a 5 x 120mm PCD and would require an adaptor to fit a Defender. There was also a 8" x 16" steel option for the P38/Disco2 (ANR5829). A Disco1 steel wheel will fit a Defender, but they are monstrously ugly!
Anything else you want to know about them? Very Happy
Post #463472 15th Oct 2015 12:39pm
GypsySamuraiAnt
Very comprehensive thanks Wolf Bow down just to be cheeky though what do they weight? Mr. Green
Post #463897 16th Oct 2015 9:38pm
More than you expect!
TBH I can't remember, but there is a loooong thread on that very subject somewhere on this forum.
Post #463906 16th Oct 2015 10:07pm
