![]() | Home > Wheels & Tyres > Offset question |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17859 ![]() ![]() ![]() |
From http://www.defender2.net/forum/topic35064.html
GypsySamuraiAnt Member Since: 31 Mar 2015 Location: Brisbane Posts: 131 ![]() ![]() ![]() |
Thanks mate
Sorry just confirming they are 16x7's?
Cheers |
It will be HD steel Wolfs listed above but they could be 16 X 7.5. You may need to examine the markings carefully.
![]() Treat every day as if it is your last....one day you will be right!! |
Assuming that they are genuine, they'll be 6.5 J 16.
Spec: Width 6.5" Profile J Diameter 16" Offset +20.6 mm Load rating 2200 Kg Studs 5 PCD 165 mm Part Number ANR5593 (Tube type), ANR4583 (Tubeless) The only 7"x16" steel rims LR has ever made are Disco1 standard steels (NTC5193) and P38/Disco2 standard steels (RRC114560MUW) although the latter is of course on a 5 x 120mm PCD and would require an adaptor to fit a Defender. There was also a 8" x 16" steel option for the P38/Disco2 (ANR5829). A Disco1 steel wheel will fit a Defender, but they are monstrously ugly! Anything else you want to know about them? ![]() |
Very comprehensive thanks Wolf
More than you expect!
TBH I can't remember, but there is a loooong thread on that very subject somewhere on this forum. |
