![]() | Home > Td5 > Steering issues |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
Hi guys, just thought i would ask if anyone knew what might be on the way out as my steering suddenly goes stiff every once in a while and then is fine the next second.
I have checked the pump and its dry on the outside and no drips or leaks. The 110 has done 115000 miles now so think it might need a new pump. What are your thoughts? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Is the reservoir topped up? 2002 90 Td5 Station Wagon
Check the steering uj's. They can tighten up.
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
Silly as it sounds check both froot wheel bearings as well....
Reservoir is fully topped up and the UJ's were done up tighter earlier in the year due to a vibration from the steering.
The other thing is that it goes and stiff and loose randomly. If it is the power steering pump, does anyone know a good place to get it fixed and also do you know how much it roughly costs to get done? |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5126 ![]() ![]() ![]() |
If it is the power steering pump, and do you mean the pump rather tha the box pumps can have new seals fitted that cost about £15.00. If you mean the power steering box box you would be better buying new or should I say reconditioned they cost about £250.00. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
It's not the tie bar bent and rubbing on the aluminium guide thingy that's bolted on the back of the diff casing, or something somewhere else snagging?
