Home > Td5 > Steering issues
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Steering issues
Hi guys, just thought i would ask if anyone knew what might be on the way out as my steering suddenly goes stiff every once in a while and then is fine the next second.
I have checked the pump and its dry on the outside and no drips or leaks. The 110 has done 115000 miles now so think it might need a new pump.
What are your thoughts?
Post #463057 13th Oct 2015 10:14pm
grafty99
Is the reservoir topped up? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #463066 13th Oct 2015 10:35pm
williamthedog
Check the steering uj's. They can tighten up.
Post #463109 14th Oct 2015 7:34am
windymiller
Silly as it sounds check both froot wheel bearings as well....
Post #463111 14th Oct 2015 7:43am
charliebaja
Reservoir is fully topped up and the UJ's were done up tighter earlier in the year due to a vibration from the steering.
The other thing is that it goes and stiff and loose randomly.
If it is the power steering pump, does anyone know a good place to get it fixed and also do you know how much it roughly costs to get done?
Post #463277 14th Oct 2015 6:39pm
gilarion
If it is the power steering pump, and do you mean the pump rather tha the box pumps can have new seals fitted that cost about £15.00. If you mean the power steering box box you would be better buying new or should I say reconditioned they cost about £250.00. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #463282 14th Oct 2015 6:47pm
JWL
It's not the tie bar bent and rubbing on the aluminium guide thingy that's bolted on the back of the diff casing, or something somewhere else snagging?
Post #463346 14th Oct 2015 9:44pm
