Home > In Car Electronics > 2015 Defender Nearside Speaker Wiring Missing?!
DerekV
United Kingdom 2015 Defender 110 Puma 2.2 SW Montalcino Red
Hi,
This is my first post! I tried searching but couldn't find anything!
I've just picked up a new Defender 110 Station Wagon. It didn't come with a stereo, but was supposedly "stereo prepared". I've fitted the driver's/offside speaker, but after hours of searching, I can't find the wires for the passenger side speaker anywhere! There is a little black (Molex or similar) connector taped up on the loom near to where I would expect to find the speaker wire, but spade connectors like those on the drivers side are nowhere to be seen!
I've spoken to Land Rover and they didn't know what I was talking about, so any help on this would be greatly appreciated!!
Thanks.
Derek.
Post #462545 12th Oct 2015 1:00pm
Martin
Site Admin
Wire colours is really the only way to identify what you are after...
Front RH side colours are Black with pink and Black with red.
Front LH side colours are Black with white and Black with brown.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462552 12th Oct 2015 2:01pm
DerekV
Hi Martin,
Thanks for the reply.
That is interesting because the 3 pin plug has those colours going to it! Is it likely they'd fit a different type of plug instead of spade terminals on one side? Also, the o/s wiring has 4 wires going to the spade terminals (2 of the same colour on each spade) which I believe is for the (non existent) tweeter. However, the n/s has only the 2 wires to this little plug.
I've attached a picture of the plug in question.
Thanks again.
Derek
Post #462554 12th Oct 2015 2:14pm
PaulMc
The connector you've found is for the tweeter, trace its wires back, and you should find the spade terminals for the speaker (probably taped to the harness).
The front speaker wiring is like this -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #462555 12th Oct 2015 2:27pm
Martin
Site Admin
Agree with Paul, you have found the tweeter plug so you will have the spades terminals in there somewhere. Happy hunting Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462561 12th Oct 2015 2:51pm
DerekV
Found it!! Very Happy Just finished. Thanks Martin and Paul. The wires were located taped to the bar near the bulkhead behind the passenger cubby/shelf. Great position!! Impossible to reach as the wiper motor was right in the way! Took the tweeter grill and passenger grab handle off and with judicious use of a bent coat hanger and some duck tape finally managed to get the tape off the wires!! Very Happy Very Happy
Thanks again.
Derek.
Post #462646 12th Oct 2015 6:52pm
