![]() | Home > In Car Electronics > 2015 Defender Nearside Speaker Wiring Missing?! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Wire colours is really the only way to identify what you are after...
Front RH side colours are Black with pink and Black with red. Front LH side colours are Black with white and Black with brown. ![]() ![]() |
DerekV Member Since: 12 Oct 2015 Location: Surrey Posts: 39 ![]() ![]() ![]() |
Hi Martin,
Thanks for the reply. That is interesting because the 3 pin plug has those colours going to it! Is it likely they'd fit a different type of plug instead of spade terminals on one side? Also, the o/s wiring has 4 wires going to the spade terminals (2 of the same colour on each spade) which I believe is for the (non existent) tweeter. However, the n/s has only the 2 wires to this little plug. I've attached a picture of the plug in question. Thanks again. Derek |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
The connector you've found is for the tweeter, trace its wires back, and you should find the spade terminals for the speaker (probably taped to the harness).
The front speaker wiring is like this - ![]() Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Agree with Paul, you have found the tweeter plug so you will have the spades terminals in there somewhere. Happy hunting
Found it!!
![]() ![]() ![]() Thanks again. Derek. |
