![]() | Home > Td5 > Front lower door seals |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
I have a pair of the L shaped door seals such as these > http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...2083673305
How far from the door panel does the seal sit? or does the seal sit up against the door panel? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I think I am with you. If you are passing by your doors with a camera - could you take a pic please? 1999 Defender TD5 110
I googled and found some pics.
The td5 style seals: ![]() Click image to enlarge ![]() Click image to enlarge I connected my seals to the piece off metal shown on the btm off this picture: ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I should have googled as well - Thanks
That looks about 10mm from the panel side of the door? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I'll check tomorrow where the poprivits are in my old td5 door are located. Roel
Some pics:
I measured were the pop-rivuts were on the original td5 door: ![]() Click image to enlarge The btm off the door is 3cm between the doorskin and the innerside and the poprivuts are about in the middle. I put the seal here: ![]() Click image to enlarge ![]() Click image to enlarge But that is not 100% nice. ![]() Click image to enlarge It just extends below the door. I installed them there as I hope it will protect the door more from mud that comes up through the gap between the floor and the sidebar. Just installed them this week and not been off-road yet so still have to see if it works. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
