Home > Maintenance & Modifications > Stainless
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Stainless
Has anyone changed there drive flange bolts for stainless ones I have bowler wheels that leave the flanges on show I'm sure I have seen someone with Stainless Allen bolts on here ?[/list]
Post #455679 16th Sep 2015 10:55pm
I wouldn't use stainless as they are not hi tensile and more prone to seize or shear.
Not that stainless is bad, far from it but just for this application.
Post #455687 16th Sep 2015 11:21pm
Triggerfinger
As said I wouldn't use stainless try drilling a damaged or sheered stainless bolt not much fun Wink
Post #455689 16th Sep 2015 11:30pm
You need 10.9 for these which I suspect rules out stainless. You could go with BZP socket head caps, or maybe get some chromed, though if you're using standard flanges why not just paint them black?
Post #455691 16th Sep 2015 11:35pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
You can get SS in a high enough tensile strength but it will be stupidly expensive just for the shine, just get some paint on them or some acorn nut caps and stick them on with silly cone
Post #455693 16th Sep 2015 11:45pm
mikeh501
There is no equivalent SS bolt which matches a normal steel 10.9 bolt ive seen. possibly some very specialised stuff i wouldn't know about.
Common stainless is either A2-70 which does not equal a 8.8 bolt, and A2-80 which is about the same as a 8.8 steel bolt.
Ive used A2-80 on certain suspension components but nothing under significant load. I wouldnt use any stainless on calipers, hubs, swivels, drive members etc etc.
Post #455723 17th Sep 2015 8:42am
rallysteve
A2 Grade is 304 grade stainless and A4 is 316 grade.
Generally the higher strength stainless bolts available are A2-70 (not very strong and corrode with chlorine environment) and A4-80 (comparable to grade 8.8 bolts and better corrosion protection.)
If you would like it to look better than standard, I would get some BZP grade 12.9 socket head bolts (http://www.namrick.co.uk/acatalog/Home_Metric_Socket_Cap_Head_Screw__Grade_12_9_Zinc_Plated__34.html), clean and degrease the drive flange and lacquer the whole area (with the splined centre masked off)
Post #455739 17th Sep 2015 9:58am
dave18
Mikeh501, I doubt High Tensile Stainless would be used in automotive but I have used them in non automotive applications where there is certain corrosion or temp issues, As said they would be STUPIDLY expensive.
Post #455781 17th Sep 2015 12:50pm
Clive
I've fitted new BZP 12.9 cap heads on mine when I replaced the drive flanges, bought them from the local builders hardware supply shop, fraction of the price of the original LR ones and nice 'n shiny Thumbs Up
Post #455818 17th Sep 2015 3:08pm
