Home > Technical > Odyssey Batts
Page 2 of 2 <12
need4speed
I knew this would happen. Battery threads are like tyre threads - you could ask 50 people which is best and get 25 different answers..
I noticed you posted same thread over on lr4x4 where opinion on them seem to be a little more favourable.
Post #455247 15th Sep 2015 3:35pm
jst
Hairysteve wrote:
I am looking into buying all the bits to fit a dual battery solution in my 110 and the costs of the batteries are IMHO extortianate Big Cry . My requirement is that the batteries are the same model (personal choice) and fit in the space allocated in the tray, what do you experienced folks propose as alternates?
hence my post really.
Won an Odyssey 1500 last weekend at a challenge event. i was am putting a split charge in the 110 and upto last weekends win i was going to use 2 of Numax. now i am thinking of getting another Odyssey. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #455340 15th Sep 2015 8:31pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Why do you want them both the same???
General vehicle batteries dont like to be drawn right down and cycled as much as Leisure batteries, You can get two the same physical size relatively easily if that helps.
Post #455386 15th Sep 2015 10:10pm
landy andy
I've run these for many years, and only had one problem with one, once. I then spoke to the manufacturer who told me that the problem I was having was due to the battery not being used enough, and it should be fully charged with a good quality charger. There advise was to once a year give both batteries a good charge via mains charger and alternate between my starter and leisure battery. Since then, that is what I've done and have noticed an improvement with the batteries in all operations.
Andy
Post #455406 15th Sep 2015 11:30pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Hi Dave,
Decision made what I had read here http://www.mobilecentre.co.uk/images/Data_...ue_Sea.pdf
"Because we are joining the batteries in parallel, the make-up of the batteries used and their internal resistance need to be as similar as possible, so there is no risk of a charge imbalance caused by two different batteries having different charging requirements"
Steve
Post #455416 16th Sep 2015 6:06am
ericvv
Post #455418 16th Sep 2015 6:29am
Hairysteve
Just read that, thanks for sharing Thumbs Up
Post #455419 16th Sep 2015 7:03am
pannawonica
Australia
I chucked a couple in12 months ago, used all blue sea gear from the mobile centre. ( very good service!) now where I live and with ambient temps the expectation is for a good battery is too last two years. I will let you know. However like already said, bit like fuel consumption it's very hard to be definitive! I will report in time when l chuck em! Very Happy Thumbs Up
Post #456042 18th Sep 2015 11:23am
jst
Correct on lr4x4 post.
From here then it would seem they are not worth the £££ Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #457839 24th Sep 2015 8:17pm
I've had my odysseys for 4 years, still going strong... When the truck is in storage they are on the ctek
Post #457852 24th Sep 2015 8:38pm
Page 2 of 2 <12
