![]() | Home > Td5 > Help Please Diagnostic plug won't read on snap on machine |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Does the Snap-On machine support the TD5? 1999 Defender TD5 110
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 ![]() ![]() |
Mine does ..
Check your fuses are all ok . |
D922MAT Member Since: 19 Sep 2013 Location: uk Posts: 65 ![]() ![]() ![]() |
yes iv checked all fuses all ok. I'm using a new ethos snap machine iv gone through the menu an in comes up with 2004 defender models covered. is there a check list i need to go through
thanks |
Strange , I used mine on a 2000 Td5 with no problems to check the engine and abs .
Can you check with another system? My 90 has a similar problem, I can read data etc with my Nanocom but to program my ECU and AS10 they have to be put in another vehicle, they don't accept it in my 90.
I also get regulary a message when starting the Nanocom: Cannot init with the ECU (or something like that). I have to switch the engine off and wait a minute and start again. Most off the times it will work then. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
