Home > Td5 > Help Please Diagnostic plug won't read on snap on machine
D922MAT
United Kingdom 2004 Defender 110 Td5 XS DCPU Loire Blue
HI guys
I'm building my 110 crew cab 2004 pickup at the moment. Iv gone to plug a snap machine in to clear any fault codes on the ecu an I'm getting nothing back. Can any ono help with a wiring diagram or but any ideas where to start looking for a broken wire
thanks Matthew
Post #453178 7th Sep 2015 9:49pm
excossack
Does the Snap-On machine support the TD5? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #453181 7th Sep 2015 9:58pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Mine does ..
Check your fuses are all ok .
Post #453182 7th Sep 2015 9:59pm
D922MAT
yes iv checked all fuses all ok. I'm using a new ethos snap machine iv gone through the menu an in comes up with 2004 defender models covered. is there a check list i need to go through
thanks
Post #453183 7th Sep 2015 10:04pm
grizz
Strange , I used mine on a 2000 Td5 with no problems to check the engine and abs .
Post #453232 8th Sep 2015 7:17am
roel
Can you check with another system? My 90 has a similar problem, I can read data etc with my Nanocom but to program my ECU and AS10 they have to be put in another vehicle, they don't accept it in my 90.
I also get regulary a message when starting the Nanocom: Cannot init with the ECU (or something like that). I have to switch the engine off and wait a minute and start again. Most off the times it will work then. Roel
2003 90 Td5 (2009-now)
Post #453257 8th Sep 2015 8:26am
